Jan 13, 2011 22:21:45 GMT
My first thought is Anglia, as the cover is tight at the top of the rear window (assuming the rear is closest), but does not show any lines down the sides, but the 'boot' area seems too long for that. Could be a Humber Sceptre?
MrT
Just who did Mr Hitler REALLY think he was kidding?
Jan 13, 2011 22:24:09 GMT
Depends how big it it, but I reckon that might be a Dolomite or a Superminx/Vogue...
crazymonkey
ummm....what was I doing again???
Jan 13, 2011 22:30:45 GMT
looks like a 4dr anyway, its not big enough for a rover is it? could be a triumph then. Although correct me if I'm wrong but where the cover is pulled tight at the back, the rear window seems quite vertical, almost like a lada
whoever said dogs were man's best friend....obviously never heard of cable ties
Jan 13, 2011 22:31:21 GMT
just knock on the door and ask if they want to sell the car and then they might show it to you
Jan 13, 2011 22:34:08 GMT
... and ask if they like dawgs. ;D
Jan 13, 2011 22:37:30 GMT
I'm sticking with this...
Last Edit: Jan 13, 2011 22:40:07 GMT by Fennec
Jan 13, 2011 23:21:26 GMT
'94 Cavalier GSi
Copey
Jan 13, 2011 23:22:49 GMT
am thinkin a Dolomite
Jan 13, 2011 23:26:53 GMT
The nose doesn't look right to be a dolly though. It looks like it's got coweled (Or something like that) headlights.
skinnylew
Club RR Member Number: 11
Jan 13, 2011 23:28:03 GMT
first thought was a Dolly or Toledo. but that second photo almost looks like it could be a Cavalier mk2 hatch ish...
Jan 13, 2011 23:30:50 GMT
I was going to say mk2 cav or maybe a princess?
Jan 13, 2011 23:31:26 GMT
My first thought is Anglia, as the cover is tight at the top of the rear window (assuming the rear is closest), but does not show any lines down the sides, but the 'boot' area seems too long for that. How about a Consul Classic? Same sort of rear window shape, but bigger
1989 Peugeot 205. You know, the one that was parked in a ditch on the campsite at RRG'17... the glass is always full. but the ratio of air to water may vary.
crazymonkey
Jan 13, 2011 23:31:46 GMT
Actually looking at it you can just make out the actual bodywork under the cover, it has almost a rover 213 back end, possibly a bmw 3 series (E30?)
Copey
Jan 13, 2011 23:33:54 GMT
My first thought is Anglia, as the cover is tight at the top of the rear window (assuming the rear is closest), but does not show any lines down the sides, but the 'boot' area seems too long for that. How about a Consul Classic? Same sort of rear window shape, but bigger I thought that too, but the boot looks too flat could be right though
Last Edit: Jan 13, 2011 23:34:28 GMT by Copey
Jan 13, 2011 23:35:32 GMT
triumph 2000 mk2 methinks
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Jan 13, 2011 23:48:12 GMT
I thought Dolomite as soon as I saw it. But I don't think it is.
Rover P6 I reckon. Wing, not door mirrors. That rear edge of the roof. I think the flat back is a red herring-the tarp's just stretched between the tops of the rear wings; in the first picture you can see the corner isn't as sharp as the second makes it look.
" East bound and down, loaded up and truckin' "
i was thinking dolly too.
theres more to life than mpg & to much power is just enough.
Jan 14, 2011 10:42:38 GMT
I'm with Pandamonium on this one. Superminx/Vogue/Sceptre I reckon
1953 Austin A40 Somerset 1959 Austin A35 1958 Austin A55 Cambridge 1975 Vauxhall FE 2300S 1985 Austin Maestro 1.3 Base
Jan 14, 2011 11:03:09 GMT
Stack of pallets roughly in the shape of a car.....
