guiguicustoms
@guiguicustoms
Nov 19, 2011 17:39:55 GMT |
original as plan plutot! good luck!
Nov 19, 2011 22:00:29 GMT |
I like the wheels.
Body looks to be in good shape too .
Be nice to see that engine finally fitted in a Kadett !
countvauxalot
@countvauxalot
Nov 19, 2011 22:28:03 GMT |
Be nice to see that engine finally fitted in a Kadett ! Tell me about it lol!
countvauxalot
@countvauxalot
Nov 20, 2011 20:28:14 GMT |
Evening People, I got out and did 40miles in the car today and it was as good as gold, even the missus didn't mind it. Had a few strange looks in sainsburys car park too!  When i got home i went up the workshop to carry on with the engine mounts. I flipped the O/S mount over to finish we;ding it up   Ive been using MIG but TIG would have made a neater job, unfortunately i don't have access to a TIG welder so that's that   the new mount clears the water pipe fine  Then it was back to the other side, where i welded round the tubing that sits on top of the rubber engine mount  Zap  And started on the triangulation to it - at which point my electric ran out so that was the end of that! Last couple of pics were in the dark    James
countvauxalot
@countvauxalot
Nov 21, 2011 21:57:19 GMT |
Greetings good people! I had a couple of spare hours after work tonight so i got on with the inlet manifold. I started with this  I needed to lower the edge closest in the pic so the plate sat flush with the plenum  So i removed this pesky beast and did some more fettling  Getting there   Turning my attention to the manifold its self i removed this water way as it was in the way  i will address this mess later  With that out of the way i could linish the manifold flat and to the required angle  As so  Allowing the plenum sit like this    Getting fed up of holding it i decided to zip tie it in place so i could take some better pics and a few measurements  I'm happy with the way it is sitting now
countvauxalot
@countvauxalot
Nov 22, 2011 20:08:09 GMT |
Pleasingly more Progress was made this evening  Volvo 4 pots stripped  De greased  Hot washed  And dried  Looking much better and ready for some further cleaning  Then back to the manifold - marked the important areas out   Card board lends a hand  All marked out  on to the mill  Test run  First one done  Then there were 3   stage one complete   Then put a nice chamfered profile on the edges  Stage two complete  It came out ok for a 'by eye effort'  The plate goes here on the manifold  And looks like this inside the plenum  I will probably finish the profile by hand to get them spot on Thanks for looking James
madspikes
Wrong wheel drive!
Nov 22, 2011 22:03:49 GMT |
Looking really good - I really enjoy following some nice engineer!
orangecords
yawner extraordinaire
Nov 22, 2011 23:25:50 GMT |
thats a lovely chariot mate. i had one years ago. kinda miss it
I then wanted to start cleaning the interior as it stinks of wood (the material not the smell of a boner) best quote ever!
rodney
Nov 22, 2011 23:56:46 GMT |
GOTTA LOVE A HOME BUILT ENGINE  reckon the rear wheels would look beter with some spacers ,.
robb
Looking sweet, Man! When i was reading this thread i thought to myself that i saw a similar one in my home town of worthing and someone previously posted that it was bought from worthing. I used to see it driving around Worthing every now and then, If i remember correctly there was either a young asian woman or a faily old asian man. Fairly looked after though!
countvauxalot
@countvauxalot
/\ your correct thats the guy and his daughter i brought it from...small world!
@stealthstylz
Nice fab skills. I can't decide whether I think the rear wheels need spacers or not. Some pics say yes, others no.
Matt
Nov 23, 2011 14:58:59 GMT |
That looks so good that you could turn a Ford man to the darkside ;-)
countvauxalot
@countvauxalot
Nov 23, 2011 16:53:06 GMT |
GOTTA LOVE A HOME BUILT ENGINE  reckon the rear wheels would look beter with some spacers ,. Nice fab skills. I can't decide whether I think the rear wheels need spacers or not. Some pics say yes, others no. Matt I know where you are both coming from here, the new axle will space the wheels out any way so i may not need spacers or have a choice once its fitted. Ideally i would like the rims to be wider with more dish but they will do for now
countvauxalot
@countvauxalot
Nov 23, 2011 16:59:51 GMT |
That looks so good that you could turn a Ford man to the darkside ;-) Now thats a true compliment ;D
Nov 24, 2011 21:52:52 GMT |
Looking forward to more progress on the mounts and installation as I have got most of the bits for a similar (corsa GSi non turbo/ type 9 'box) job. Wont be as nice as yours with all that neat machining and ally work though!
Sittin' here in a hired tuxedo. Wanna see my bacon torpedo?
countvauxalot
@countvauxalot
Nov 26, 2011 18:59:35 GMT |
Thanks Curryracer i would be interested to see what your up to with yours! I've made a small amount of progress with the manifold however i have been working on my 944 today so i haven't had any time for the Kadett  Manifold progress I machined this edge off to help the air flow inside the manifold  Then chopped off the excess Ali from the back plate (annoyingly my plasma needs a new tip so it was a pita to cut up neatly)  And neatened it up a little - nearly ready for welding!
tsp
Nov 27, 2011 20:38:18 GMT |
You are one talented dude  You can build an engine for my mk1 if you like...
callumaspinall
@callumaspinall
what did you use for lowering did you use coilovers or just cut the springs !!!!
DREAMER
