Dec 23, 2011 10:15:32 GMT |
iv'e had this car for four years now. bought MOT''d 'n' taxed i ran it for a couple of weeks before deciding it's way too slow. the original engine is a very nice design but very very difficult to work on with the roller bearing motorbike style crank etc. i decided a modern engine was the answer. it was already modified with uprated suspension and a fibreglass front end being that it was a track car. i didn't want to fit a motorbike engine but wanted to keep it Honda. S2000 engine was the only choice really. it'll be slightly down on power as i'm fitting Webers for ease of tune etc. it'll still be quick enough. the transmission tunnel on this car is huge. so much so that i have trial fitted a Honda S2000 engine and six speed gearbox without cutting the transmission tunnel. and the engine is further back than the original. ;D for such a small car they are really heavy. nearly 800kgs  . this is due to the thing being over engineered. everything uses heavy gauge steel. saying that i'm also over engineering the chassis to beef it up. i want a lot of weight low down to help keep the centre of gravity low so 3mm plate is being welded into key areas as well as a few extra tubes. the suspension is being beefed up as well as modifing some Renault 5 Turbo vented discs to fit the original front hubs. some modern calipers will provide the braking force. at the rear there will be a shortened Atlas Axle. i have just moved the car into a proper little workshop so the modifications can now properly start. everything before was done in a small council lockup.     and this is what it'll look like when finished  what the car used to look like many years ago. and this is what i use for the odd track day at the moment
md
Dec 23, 2011 11:23:58 GMT |
i cant wait to see this built! I'm tempted to fit the same engine to the del sol sitting outside, but it's a lot of work to convert it to RWD. best of luck with the bild, I'll be following with much interest!
Dec 23, 2011 11:45:03 GMT |
Nice.
Yeaaaars ago my dad was looking at one of these.
Look forward to the build.
79cord
Dec 23, 2011 11:46:07 GMT |
Last Edit: Dec 23, 2011 11:47:01 GMT by 79cord
V-Force
I like Hondas.
Dec 23, 2011 12:34:19 GMT |
That's gonna be mental! Looking forward to seeing in finished
1994 Honda Civic VTi EG6 - full of Integra DC2 parts under the skin 1995 Honda Prelude VTEC - Accord Type-R engine swap 1999 Honda Accord Type-R - Standard. For now. 2005 VW Bora Highline TDI 130 - mega mile daily
Long term projects: Another Accord Type-R and an EK Civic
Dec 28, 2011 21:29:48 GMT |
been busy beefing up the chassis. adding tubing and 3mm plate, welding in the engine mounts permanantly etc. chassis should weigh a ton when finished.  the great thing about this build is that i can use so much of the S800 suspension etc that it'll save a lot of time and grief. the steering rack is in the original position and the suspension is already fairly heavy duty. iv'e beefed up the wishbones and manage to graft some Renault 5 Turbo vented discs to the hubs. iv'e also made some offset nylon bushes to allow more negative camber and generally make the whole thing more positive.      still so much to do though because so much stuff needs to be modified slightly. i managed to get hold of a small rad good for cooling 300bhp, i had some front coilover shocks specially made because i'm changing the way the are mounted and so on. having the unit is a luxury compared to what i had before. iv'e done more in the last week or so than i managed in the last couple of years. ;D
10mpg
Club RR Member Number: 204
1967 Honda S800 F20c10mpg
@10mpg
Club Retro Rides Member 204
Dec 28, 2011 22:40:34 GMT |
Hell yeah!
that looks fantastic, it'll shift as well..
One question, why webbers when megasquirt would be be cheaper and probably better?
www.vikingengineering.co.uk for all your classic & custom restoration needs The Internet, like all tools, if used improperly, can make a complete bo**cks of even the simplest jobs...
Dec 28, 2011 23:05:08 GMT |
i don't want fuel inection. carbs will be fine. i know how to tune carbs and they are pretty much self regulating once jetted. i think there are very few people left who can properly tune carbs. it's like the points scenario. show a modern tech a set of points and they wont have a clue how to set them up. for most the easier option would be megasquirt as it can be done on a computer. talk about differences in emulsion tubes and they are lost. there is no guarentee that megasquirt will be better. and that is once it has been sorted to run properly. all the internet searching iv'e done shows very mixed feelings for the F20c engine and megasquirt. mostly bad. for me carbs will be fine, they will work fine and vtec will not cause them problems.
longman
Club RR Member Number: 3
1967 Honda S800 F20clongman
@longman
Club Retro Rides Member 3
Dec 28, 2011 23:21:27 GMT |
ooh lovely , looks like a great project
Paul 98 500 SL 86 911 Carrera/sold 19 Kia Sportage
I always wanted one of these for my first car, could never find one nearby worth having (Well, not for my budget at the time anyway!), looking forward to this!
1967 Honda S800 F20cretrowagen1234
@GUEST
thats amazing!! Loving the webers route too.. Imagine the NOISE! worth it for that alone ;D Ill be following this thread
Clement
ambitious but rubbish
Thread bookmarked!
Last Edit: Dec 29, 2011 8:05:13 GMT by Clement
glad to see you've got a proper unit so you can get on with this now. looks like as much fun building it as it will be driving it. as already said, this is gonna sound pretty dam good too ;D enjoy
bstardchild
Club RR Member Number: 71
1967 Honda S800 F20cbstardchild
@bstardchild
Club Retro Rides Member 71
A lot of the photo links seem to be broken for me Plus why start a new thread when the old one could be fixed? Great project that I never saw last time - I have some good memories of a MG Midget that turned up at RRG a few years back with an S2000 lump in it, it was a mental thing on track
Dec 29, 2011 10:35:06 GMT |
Dec 29, 2011 10:53:18 GMT |
One of the prettiest little J coupes ever imo,look forward to seeing it finished
1984 Subaru GLF Hatch 1983 Skoda 120LE Super estelle 1977 Subaru DL Wagon 1978 Datsun 120Y Coupe 1995 Skoda favorit estate
Dec 29, 2011 13:15:34 GMT |
Nice build.
I like the pictures taken in your 'shed', looks very professional.
 Click picture for more
Dec 29, 2011 14:01:11 GMT |
iv'e now got pretty much 5 times the amount of space and it's only costing me £25 a month more than that tiny damp council lock up it used to be in  . iv'e got another bench (bench number three) to knock up yet and could probably do with more racking at the back. the engine crane was an ebay bargain. £25 delivered  (it was only two miles away) the reason for starting another thread is because that is an old account. i deleted loads of stuff a while back.
Dec 29, 2011 15:07:38 GMT |
Yeah.. you are back onto your beast! I love to see this finished myself. I was thinking the other day I haven't seen your build updated for a while.
Cheers Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Brian Damaged
West Midlands
Club RR Member Number: 33
1967 Honda S800 F20cBrian Damaged
@damaged
Club Retro Rides Member 33
Dec 29, 2011 16:50:41 GMT |
If this car is finished in 2012 I'd bank on it being one of, if not THE cars of the year next year.
Awesome. REALLY looking forward to seeing how this progresses.
