tee
Mar 12, 2012 13:05:22 GMT
Hi guys, chugging along and I get a crazy suffocating smell, popped boot and the battery was leaking and had bulged out! I'm assuming regulator has gone on alternator causing overcharge..?
I've heard there's a few Lucas alternators that fit my car, it's a 70's Silver Shadow 2. I'm trying not to fork out top whack for a new Rolls Royce one, anyone know what other models fit? Ta
T
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Mar 12, 2012 13:49:09 GMT
Do you know what alternator it is? If it's a Lucas one then it shouldn't be difficult to find an alternative
Mar 12, 2012 14:46:50 GMT
any pics of the alternator? If it's a Lucas one, there's bound to be virtually hundreds of possible donor cars, depending on its shape ;D
Mar 12, 2012 17:46:16 GMT
swap regulator only ?
MrSpeedy
East Midlands
Mar 12, 2012 17:50:14 GMT
That is the cause of the overcharging tbh. Depending on which alternator it is, it could even be a remote 4TR or similar regulator. Pics are needed!
Mar 12, 2012 18:12:16 GMT
Porsche
West Midlands
Kev from B'ham.
Mar 12, 2012 19:34:47 GMT
I've got Lucas catalouges in my garage, but I'm not by them at the mo' so I'll have a check tomorrow for ya, but after searching the net I've come up with this....
LRA02864, 12 Volt, Int. Regulator EXCHANGE ALTERNATOR 180A BMW
Make Model ccm Date BMW 735i 3.6 (E65 E66) 3600ccm N62B36A 01-03 BMW 745i 4.4 (E65) 4398ccm N62B44A 01-03 BMW 745i 4.4 (E66) 4398ccm N62B44A 02-03 BMW 760i 6.0 (E65) 5972ccm N73B60 02-08 BMW 760i 6.0 (E66) 5972ccm N73B60 02-08 ROLLS-ROYCE Drophead 6.8 6749ccm N73B68 07- ROLLS-ROYCE Phantom 6.8 6749ccm N73B68 03- ROLLS-ROYCE Phantom coupe 6.8 6749ccm N73B68 08-
Cross ref no. 01220AA090 01220AA090WH 01220AA160 12317507741 12317507995 12317523606 12317523608 12317526286 7507741 7507995 7523606 7523608 7526286 Is your Rolls one of the above? If so, it looks like the 7 series BMW is the same.
RetroMat
Column Shifting!
Mar 12, 2012 19:57:13 GMT
I should know (cos I work on Rolls/Bentleys every day ) but cant quite remember atm. But don't shadow 2s have the alternator regulator in the boot next to the battery? I'm sure i've fitted a durite equivalent/replacement to one before.
MrSpeedy
East Midlands
Mar 12, 2012 21:55:56 GMT
If it is an AC5 then originally it would have an external regulator, but they can be converted and fitted with modern inbuilt regs. I think we may have a recon unit on the shelf, so let me know if you want it.
30psi
Mar 12, 2012 23:28:20 GMT
The Lucas althernator on my Thunderbird cost me £52 to replace. It was on the shelf in the shop I went to
1962 Ford Thunderbird 6.4L
1981 Datsun Bluebird SSS CA18DET
1981 Datsun Bluebird SSS SR20DE
Mar 12, 2012 23:47:55 GMT
Make Model ccm Date BMW 735i 3.6 (E65 E66) 3600ccm N62B36A 01-03 BMW 745i 4.4 (E65) 4398ccm N62B44A 01-03 BMW 745i 4.4 (E66) 4398ccm N62B44A 02-03 BMW 760i 6.0 (E65) 5972ccm N73B60 02-08 BMW 760i 6.0 (E66) 5972ccm N73B60 02-08 ROLLS-ROYCE Drophead 6.8 6749ccm N73B68 07- ROLLS-ROYCE Phantom 6.8 6749ccm N73B68 03- ROLLS-ROYCE Phantom coupe 6.8 6749ccm N73B68 08- Is your Rolls one of the above? If so, it looks like the 7 series BMW is the same. [/b][/quote] He said a '70s RR, and the oldest one you listed was made in the next millenium - wouldn't think it would be one of them tbh.
OVY871
Owner of Austin A35 Saloon
Club RR Member Number: 66
Make Model ccm Date BMW 735i 3.6 (E65 E66) 3600ccm N62B36A 01-03 BMW 745i 4.4 (E65) 4398ccm N62B44A 01-03 BMW 745i 4.4 (E66) 4398ccm N62B44A 02-03 BMW 760i 6.0 (E65) 5972ccm N73B60 02-08 BMW 760i 6.0 (E66) 5972ccm N73B60 02-08 ROLLS-ROYCE Drophead 6.8 6749ccm N73B68 07- ROLLS-ROYCE Phantom 6.8 6749ccm N73B68 03- ROLLS-ROYCE Phantom coupe 6.8 6749ccm N73B68 08- Is your Rolls one of the above? If so, it looks like the 7 series BMW is the same. [/b][/quote] He said a '70s RR, and the oldest one you listed was made in the next millenium - wouldn't think it would be one of them tbh.[/quote] He also said: it's a 70's Silver Shadow 2. So no its not one of those but I'm sure he'll appreciate the help.
Porsche
West Midlands
Kev from B'ham.
Mar 13, 2012 16:04:13 GMT
He said a '70s RR, and the oldest one you listed was made in the next millenium - wouldn't think it would be one of them tbh. He also said: it's a 70's Silver Shadow 2. So no its not one of those but I'm sure he'll appreciate the help. Sorry about that guys....it was just a quick internet search.
Anyhow, I've now got my old Lucas Exchange Units catalogues in front of me, and guess what? They don't list Rolls-Royce.
But all is not lost, if you can remove the alternator and tell me what the part number is (It should be on the plastic end cover) I can cross reference it and find out what other makes/models it was fitted to. The part number should start with LRA.
tee
Mar 13, 2012 20:26:36 GMT
Thanks a mill guys your legends, I'll check part number on alternator tomorrow, I've actually managed to source a used one for £75 plus £25 for the regulator, should have asked but I assume as separate prices they are separate units. I'll post up part number tomorrow Porsche
T
tee
Mar 16, 2012 12:58:52 GMT
Ive decided to get the regulator changed first, part number of this is: 1697-D222. Going by Rolls Royce SS alternators on eBay, it seems mine is a CAV AC5 12-53 12 Volt alternator. What other models have this?
T
tee
Mar 25, 2012 15:43:09 GMT
Still having problems with this. Does anyone know if I can get an alternator with a built in regulator and fit this to the Rolls? Also looking at the pics below, as you can see the regulator shows High, Medium and Low. On mine there are wires on all 3. Seems strange, I have however been driving it around like this fine for a few weeks now until the overcharge problem started. Any auto-electricians out there around Leicester area..
Last Edit: Mar 25, 2012 15:43:45 GMT by tee
T
