Mar 22, 2012 19:55:18 GMT
The 'Wheels borrowed from other makes' thread has pushed me over the edge into finally asking how they do it.
Swapping wheels between manufacturers who use the same PCD makes sense.
How on earth do you get 5x120 BMW wheels onto Japanese 5x114.3 hubs, or L200 rims onto a VW Vento?
I want to know because I need ET0 (ish) offset to go onto 4x114.3 for the Scimitar. Choices are limited for off-the-shelf in that fitment. Anyway I'd like to explore a more inventive solution, like BMW 5-series or 4x4 rims.
Mar 22, 2012 19:57:34 GMT
you can use wheel adapters(wheel spacers) so you can change the stud pattern
col
wut
Mar 22, 2012 20:01:22 GMT
yeah, most likely pod adapters they're usually canny hefty, 20mil+ so that should help you get the et0 you're after too. popular sizes are usually available off the shelf, but you can get them custom made if you're after something more unusual.
Mar 22, 2012 20:04:01 GMT
Understood. I see them available in common combinations, but the some of the combinations I see (and am considering) suggest custom made items.
Mar 22, 2012 20:11:08 GMT
So maybe my question is where can you get them made, and for how much?
bmboy
great age!
Mar 22, 2012 20:30:04 GMT
If you go to a local machining shop they should be able to help you make a spacer. I had a set made from mild steel. I gave them an old wheel to measure how it fitted to the hub (so the adapter was hub-centric) then gave them the PCDs and the nut I would be using and they charged me about £200 for it. Maybe a touch more. In my case it was 4x130 to 5x130 so I used one of the four studs as a shared one (sleeved nut goes all the way through from the wheel) then the other 3 studs bolted the adapter on. Then the adapter had helicoiled threads inserted and the wheel bolted to that!
Skoda Estelle 120l x3 Skoda Favorit Triumph Dolomite Mercedes-Benz 190E BMW 635csi BMW 528I Volvo 850 Mercedes-Benz 230TE Skoda 136 Rapid
Porsche
West Midlands
Kev from B'ham.
Mar 22, 2012 20:36:19 GMT
Could you not fit hubs from another car also?
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Mar 22, 2012 21:50:00 GMT
Could you not fit hubs from another car also? Probably possible, but pretty much guaranteed to need machining. I made a set about 12 years ago for my old Sprintfire to fit Vauxhall fitment alloy wheels on it. I used aluminium with helicoil thread inserts. Used to drive that car hard (including round Mallory at RRG 07) and never had a problem.
Mar 28, 2012 18:42:50 GMT
Easy peasy ;D These: Are for the L200 wheels on my Vento:
Mar 30, 2012 17:37:23 GMT
Hey Dominoka, those wheels look amazing on the Vento. I'm sure they're a major talking point. I guess the adaptor is hub-centric, but the wheels are lug-centric on the adaptor ?
Do you mind me asking who machined those? From the reg. it looks like you're up north too.
