Hi guys, Quick question. I have a car I want to MOT, the only thing I can see it failing on is a 2p sized hole under the windscreen/rubber on the scuttle panel. Is this a fail though? It isn't a bonded screen, so shouldn't be classed as structural would it? Thanks chaps
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Should be fine, ive MOT'd many 2CV's and Dyanes over the years with bigger holes than that in the scuttle area
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
A 2cv is a separate chassis tho.
No idea in the OP's question, sorry. But I'm sure someone will be along soon with the answer.
stinkwheel
good point, i didnt think of that. possibly best to ignore my last bit of advice Although with luck its treated the same as rusty arches, OK to pass as long as its not likely to tear open a pedestrian (although he would be bouncing off the screen by the time he got attacked by a rusted scuttle)
Gaffer tape over the top stop the jaggered edge being a fail
Gaffer tape AKA 'restoration tape' to a vdubber..
no you will be fine its not within 12" of the suspension mounts.
bl1300
Can't see that being anywhere near a prescribed area. Certainlly not within 30cm.
Prescribed areas include. Body mounts (if seperate chassis) Suspension mounts, Subframe mounts, steering system mounts and Seat belt mounting points. Also any corrosion likely to affect the steering or braking of the vehicle constitutes a fail. Then there is also the sharp edges rule. I cant really see anything on the scuttle being within those areas.
I'm not a tester but that is my understanding of the testers manual which is published on VOSAs website.
Current fleet.
craig1010cc
Club RR Member Number: 35
if it is a mini, then it could be within 30cm of the top subframe mount. But I think it should be fine with a bit of tape over any sharp edges.
May 13, 2012 16:37:31 GMT
Cheers for the replys, guys Looks promising. I'll get booking an MOT then
