I've heard Clio wipers are light, be worth checking out those and a few other light moderns inc Honda Insight etc. Possibly consider rear units? Or vacuum units off old Yanks weigh pretty little (I've got one you can have if of interest but it won't do much wiping under what conditions!) - or maybe just delete the whole system if you don't need an MoT (but that won't do much wiping under any conditions! Cheers Matt Hi Matt The car will be road legal so has to be MOT compliant. It won't be used in the wet so the wipers just have to work at MOT time :-) Have you got a photo of the Yank Vacuum unit? Regards Steve
As someone else said size up a rear wiper motor unit of something small.
fer4l
Testing
Club RR Member Number: 73
This is roughly what it looks like
Darkspeed
Club RR Member Number: 39
It may be that an MX5 headlamp lifter motor may work - rear motors are nice and small, I have a MK5 Escort one around here somewhere and it was small and light.
This is roughly what it looks like Thanks. Looks a tad complicated :-) How much does it weigh?
As someone else said size up a rear wiper motor unit of something small. Had a look at these. They would require new mounts and (I think) wiper actuator. Although I am not afraid of a little modification/fabrication, If I can avoid it I will. In order to stick to the mantra KISS whenever possible I will simply lighten the existing motor, should be able to remove over 300gms. Also, thinking about it, the motor is one of only a few parts left of the original car :-) Thanks for your suggestions guys, they helped me to decide on what to do. Started on motor case, managed to reduce one side from 4mm to 1.35mm before one of the mill's nylon drive cogs shed some teeth. I thought I had a spare but can't find it, so that was that for the day. Yes, I know that I am nuts, but I am simply following the advice I got from a successful race car builder many years ago. Once you have removed all of the easy weight, the only way to remove the next lb (told you it was some time ago) is to remove an ounce from 16 places. With my car's present (estimated) power to weight ratio on race fuel (around 0.92bhp/Kg) each further Kg removed is worth almost 1bhp/tonne. A few more Kgs and I will be approaching 1000bhp/tonne in race trim :-)
Last Edit: Jul 3, 2016 9:17:31 GMT by nalesutol
MAN this is an awesome build, lovely bit of kit you have there.
If you looking to paint it black, with a modern twist, have a look at ETNA black.
Thanks.
Certainly an interesting colour. Took me a few minutes to work out the significance of the name.
I feel the elan has the correct curves to show off a colour like that
Darkspeed
Thanks. Certainly an interesting colour. Took me a few minutes to work out the significance of the name. Took me a while before the penny dropped regarding the association - that one was certainly an acquired taste.
I feel the elan has the correct curves to show off a colour like that Yes, there isn't a flat panel on the Elan, apart from the rear light panel.
Could you not leave the wiper motor as is, fit it for the MOT, and then just remove it and not run with one at all untill MOT time next year? You said yourself it won't be used in the wet, and you'd be saving yourself 2.7kg...
Could you not leave the wiper motor as is, fit it for the MOT, and then just remove it and not run with one at all untill MOT time next year? You said yourself it won't be used in the wet, and you'd be saving yourself 2.7kg... I could, but the car wouldn't then be road legal which is the whole point :-) If the car achieves what I hope it will, there will be people claiming that it isn't road legal so it has to be 100%.
Last Edit: Jul 5, 2016 22:47:36 GMT by nalesutol
fer4l
Testing
Afterthought - simple manual wiper?
Cheers
Matt
Afterthought - simple manual wiper? Cheers Matt That thought has crossed my mind, Chris, however........ The Road Vehicles (Construction and Use) Regulations 1986 Windscreen wipers and washers 34.—(1) Subject to paragraphs (4) and (5), every vehicle fitted with a windscreen shall, unless the driver can obtain an adequate view to the front of the vehicle without looking through the windscreen, be fitted with one or more efficient automatic windscreen wipers capable of clearing the windscreen so that the driver has an adequate view of the road in front of both sides of the vehicle and to the front of the vehicle.
Don't come much smaller. Manual override as well. "Land Rover - Yesterdays technology today"
Can't find this on his site, have you got a link?
fer4l
Testing
Afterthought - simple manual wiper? Cheers Matt That thought has crossed my mind, Chris, however........ The Road Vehicles (Construction and Use) Regulations 1986 Windscreen wipers and washers 34.—(1) Subject to paragraphs (4) and (5), every vehicle fitted with a windscreen shall, unless the driver can obtain an adequate view to the front of the vehicle without looking through the windscreen, be fitted with one or more efficient automatic windscreen wipers capable of clearing the windscreen so that the driver has an adequate view of the road in front of both sides of the vehicle and to the front of the vehicle. Might just be worth checking what the equivalent regs said when the Elan was built - the 1986 regs won't have had retrospective effect!
Hi That type of wiper motor is fitted to MGTCs, Bentley (Old style) etc so are available from Holden Classics? and others.
village
Always carries a toolbox. Because Volkswagen.......
If the windscreen is removable, that will satisfy the requirement as the drive does not need to see through a wet screen.
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
