maf260
Aug 23, 2020 17:38:48 GMT
I need to buy some 1mm metal cutting discs for my Bosch 115mm angle grinder. The 2 discs I found in its case have an expiry date of 2008(!) and I've quickly appraised myself of the reasons why they're now in the bin.
A quick look online shows there are many for sale of varying prices and with varying reviews. Given the potential danger/risk with using them I would really appreciate any recommendations you may have for decent quality discs. Although I'm an infrequent user I own the necessary equipment to wear when wielding a grinder, but am also safety-conscious!
Thanks
Aug 23, 2020 18:24:26 GMT
BOC own brand are best in my option, when price, longevity and quality/speed of cut are all considered. (made by St. Gobain who make norton etc. Last time I checked), dronco are also very good.
Other brands are also well performing but poor value for money- norton, de Walt, makita, 3M etc. Unit cost is around double or more either of the two brands above.
Abracs are curse word, avoid, as are rival, blue spot, Flexovit (st. Gobains’budget’ line). Screwfix own brand stuff is downright dangerous and should be avoided.
Aug 23, 2020 18:53:02 GMT
Used Klingspor discs for 11 years every day , working for a multi national company who would only use good quality stuff .
No complaints , last well .
glenanderson
Club RR Member Number: 64
Aug 23, 2020 18:55:24 GMT
I use Dronco by preference.
moglite
Club RR Member Number: 144
Aug 23, 2020 18:59:02 GMT
1967 Morris Oxford Traveller 1979 Toyota LandCruiser BJ40 1993 Daimler Double Six 2007 Volvo XC70 2.4D
Aug 23, 2020 19:52:38 GMT
I've got their flap discs
Aug 23, 2020 19:55:08 GMT
If you think blue spot cutting, grinding or flap discs are in any way acceptable in terms of performance or wear, go out and buy some of the aforementioned brand name ones, and prepare to be amazed.
Aug 23, 2020 20:05:06 GMT
moglite
Aug 23, 2020 21:23:40 GMT
If you think blue spot cutting, grinding or flap discs are in any way acceptable in terms of performance or wear, go out and buy some of the aforementioned brand name ones, and prepare to be amazed. Well I needed some more, so I've given some Dronco's a go. I've spent some of this weekend being amazed at Derren Brown on telly, looking forward to being amazed next weekend too
I've used Klingspor cutting discs for years now. Tried sevsral other brands and find them about the best. A couple of other brand name ones are similar but not noticably better.
While everyone likes to save money on stuff grinding/cutting discs is not the area to do that. Buy quailty and you will enjoy the difference. Plus if you buy in bulk you can get the quality discs down to a good price anyway.
ferny
Club RR Member Number: 13
Big brand names do cut better, so use the advice above. For you, it may be worth getting a diamond disc for metal. I've been using the DeWalt one and although slower and noisier than an abrasive it doesn't wear down. The date issue goes away as well. I recommend them as a "backup" for every box for that reason.
Last Edit: Aug 24, 2020 9:22:06 GMT by ferny
glenanderson
Cheers ferny , they’d not been on my radar until now. 👍
slater
Club RR Member Number: 78
Aug 24, 2020 19:32:07 GMT
In all honesty they are all much of a muchness brand wise. The vast majority of discs I use are ones other people have discarded (when you ain't paying I guess you don't bother once you have used up the first 5mm!) I've used all sorts of brands and I cant see any real correlation. All I will say is the thin discs will cut far better and quicker than thicker discs and usually the bargin basement discs are thicker (ie 1.2mm vs 0.9mm or whatever)
I think the last ones I actually bought came from parweld about 5 years ago. They are still going strong. How long they last depends how you treat them more than anything.
melle
South West
It'll come out in the wash.
I use Dronco, Tyrolit and Pferd; they all cut great and I've never had any issue with them.
maf260
Aug 26, 2020 20:59:44 GMT
Thanks for all the responses. I've bought a 10-pack of Dronco from ebay for less than a fiver including postage. Cutting will commence once they've been delivered!
Aug 26, 2020 21:31:50 GMT
As above. We currently use Wilco, because that's what the local factors keeps in stock, but have used some of the other good brands mentioned. When I tried to save some money (we go through a lot of them) I bought some cheap ones off ebay. Not only did they wear out really fast, the often split, fragmented, or broke the centres out. In the end we didn't even use them all, just chucked them out. Didn't save much in the end, buying 100 cheap discs and throwing half of them out
Aug 26, 2020 22:38:23 GMT
As above. We currently use Wilco, because that's what the local factors keeps in stock, but have used some of the other good brands mentioned. When I tried to save some money (we go through a lot of them) I bought some cheap ones off ebay. Not only did they wear out really fast, the often split, fragmented, or broke the centres out. In the end we didn't even use them all, just chucked them out. Didn't save much in the end, buying 100 cheap discs and throwing half of them out Touchwood i've never had a disc break up on me but maybe i've just been lucky. I've tended to buy whatever is cheapest on ebay but even when buying the more expensive brands the amount of wear on them doesn't seem to me to be vastly different.
The only problems i've had are when I have physically damaged the disc by dropping the grinder, other than that they have always been fine although of course you have to be careful with twisting them while in use as the really thin ones wouldn't react well to this. I always try and cut everything in straight lines for this reason.
Phil H
Club RR Member Number: 133
Big brand names do cut better, so use the advice above. For you, it may be worth getting a diamond disc for metal. I've been using the DeWalt one and although slower and noisier than an abrasive it doesn't wear down. The date issue goes away as well. I recommend them as a "backup" for every box for that reason. Nothing worse than needing the full cut off a disc and it having worm 10mm, so need to swap it.. Will be investigating one of these when I've got through the current stock (half of which are probably out of date..)
