Sept 1, 2021 20:27:42 GMT
This has come such a long way in such a short space of time. So a massive pat on the back for that a lone. The result is nice.....very nice 👌. Those 80s style decals are very similar to what I have in mind for my truck. Still....that's the least of my worries at the moment.....I can't even decide what colour its going 🤔🤔 Anyway....top work! The design and execution of it all is fantastic. It's one awesome car transporter!
Opel Commodore A Coupe Opel Rekord C Coupe Opel Rekord C Saloon Vauxhall Magnum Coupe V8 (Magnumania) Mk1 Scirocco GLS Mk1 Scirocco GLS (early chrome bumper) Corrado G60 Mk1 Cortina 2 door Pre Airflow Mk2 Escort 1300 2 Door VW LT35 Tipper Truck BMW 320D E91 Tourer
Darkspeed
Club RR Member Number: 39
You should really have cleaned it back to bare metal where the cone part of the nut bears on the wheel before you fitted them. Not only does it stop it grabbing the paint like that, it prevents the wheels working loose as the paint between the nuts and the wheel gets broken down by the clamping pressure and the heating/cooling from the brakes. You need to check them for tightness ASAP, and ideally, take them off and get the paint off. 100% - Clamping surfaces of wheels - just metal to metal - front and back. Clean the conical seats and any contact surface on the rear of the wheel back to clean metal. a Smear of anti seize will hold off corrosion.
Sept 4, 2021 14:01:16 GMT
Shame about the paint on the wheels. You should really have cleaned it back to bare metal where the cone part of the nut bears on the wheel before you fitted them. Not only does it stop it grabbing the paint like that, it prevents the wheels working loose as the paint between the nuts and the wheel gets broken down by the clamping pressure and the heating/cooling from the brakes. You need to check them for tightness ASAP, and ideally, take them off and get the paint off. Yep, this is the plan when I am back home next on all of them. Got a good idea of how to bare metal just that section around the nut and not risk the rest of the paint around it??
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
Sept 4, 2021 14:03:20 GMT
You should really have cleaned it back to bare metal where the cone part of the nut bears on the wheel before you fitted them. Not only does it stop it grabbing the paint like that, it prevents the wheels working loose as the paint between the nuts and the wheel gets broken down by the clamping pressure and the heating/cooling from the brakes. You need to check them for tightness ASAP, and ideally, take them off and get the paint off. 100% - Clamping surfaces of wheels - just metal to metal - front and back. Clean the conical seats and any contact surface on the rear of the wheel back to clean metal. a Smear of anti seize will hold off corrosion. Great, thanks for the input.. do you have a suggestion of what tool piece i can use to do this without risking any more of the paint around where I am doing it?? Great idea with the anti seize.
Sept 4, 2021 14:05:08 GMT
This has come such a long way in such a short space of time. So a massive pat on the back for that a lone. The result is nice.....very nice 👌. Those 80s style decals are very similar to what I have in mind for my truck. Still....that's the least of my worries at the moment.....I can't even decide what colour its going 🤔🤔 Anyway....top work! The design and execution of it all is fantastic. It's one awesome car transporter! It was almost three weeks worth of 10 - 14 hour days. Great, use it as inspiration to keep going! Thank you
norm75
Sept 4, 2021 14:15:13 GMT
How big are the holes that need cleaning up? Maybe get a large masonry drill bit (i.e bigger than the hole) in a drill and slowly turn it so it cleans the surface up without biting into the metal.
wildy
Sept 4, 2021 14:26:00 GMT
Shame about the paint on the wheels. You should really have cleaned it back to bare metal where the cone part of the nut bears on the wheel before you fitted them. Not only does it stop it grabbing the paint like that, it prevents the wheels working loose as the paint between the nuts and the wheel gets broken down by the clamping pressure and the heating/cooling from the brakes. You need to check them for tightness ASAP, and ideally, take them off and get the paint off. THIS ^^^^
Darkspeed
Sept 4, 2021 14:48:18 GMT
do you have a suggestion of what tool piece i can use to do this without risking any more of the paint around where I am doing it?? Great idea with the anti seize. It would be a fairly large counterbore to do that and would need to match the seat angle - I would be inclined to see what a sharp blade in a Stanley knife would do cutting the paint as it looks very plastic. Or as suggested grind up a suitable drill bit to suit the angle and use it hand held to "deburr" the paint from the steel.
glenanderson
Club RR Member Number: 64
Sept 4, 2021 14:48:35 GMT
I’d use an old screwdriver, ground to match the shape of the wheelnut, to carefully carve the paint out.
I’d definitely do it by hand with some sort of scraper, not a machine tool or anything that would likely damage the seat.
Mind you, it’s easier to not put paint there in the first place. 🤣
Sept 4, 2021 18:09:26 GMT
Sept 4, 2021 19:27:44 GMT
That sounds like a great idea. But it looks like the layer of paint is very thick and it wants to peel, so the edge is still vulnerable. I think I'd try to cut the edges first with an Exacto knife. And then clean the rest with the Pinder methode.
maf260
Sept 6, 2021 10:37:40 GMT
I'd run a scalpel around the edges first to ensure no further paint will come off, followed by gentle scraping by hand to remove the desired paint.
norm75
Sept 6, 2021 12:18:08 GMT
thats a good idea. Would it not work if used with valve seat grinding paste instead of notching the bolt, may be less risk of damaging the face the nut sits in.
Sept 6, 2021 17:12:00 GMT
thats a good idea. Would it not work if used with valve seat grinding paste instead of notching the bolt, may be less risk of damaging the face the nut sits in. Depends how long you want to sit there, I guess
Sept 6, 2021 20:23:05 GMT
Really neat job on the transporter. I have to ask though: what is your connection with Friesland?
jimi
Sept 6, 2021 22:42:25 GMT
Really neat job on the transporter. I have to ask though: what is your connection with Friesland? Yes the Motherships side is landed Gentry where as the old mans were bakers in Friesland... which makes it my birth right to eat as many cakes as I like.
Sept 9, 2021 19:27:50 GMT
Digging the FRL sticker on the back of the cab. Yes the Motherships side is landed Gentry where as the old mans were bakers in Friesland... which makes it my birth right to eat as many cakes as I like. Always fascinated me how many people of Dutch descent there were in Devon. The neighbours we had in Cully, before we moved her, were Dutch.
Todos con Lorca
melle
South West
It'll come out in the wash.
Sept 9, 2021 20:39:22 GMT
Always fascinated me how many people of Dutch descent there were in Devon. Not only in Devon, there's many of us and we're EVERYWHERE.
misteralz
Sept 10, 2021 5:59:31 GMT
True. No matter where the campsite, there'll be something there with yellow plates...
Sept 10, 2021 8:34:07 GMT
Always fascinated me how many people of Dutch descent there were in Devon. Not only in Devon, there's many of us and we're EVERYWHERE. If you ain't Dutch, you ain't much... or so the saying goes.
