Paul Y
Dec 30, 2021 13:11:07 GMT
As I am stuck here with the Corona Virus thought I would plan out the electrical circuit on Woody. Current (lol) thinking is for a battery mounted passenger side rear with positive cable running forward to a master cut off switch before moving forward to the starter and power distribution. Earth will be too chassis at the rear with a further 3 earths from the block to the chassis, chassis to the body and another, for good measure, from the block to the body. All pretty simple stuff. Question is then, anybody recommend a company to make up the required cables? Have looked on eBay, Amazon and Halfords but, before splashing out cash, wanted to hear good and bad reports or indeed any recommendations you might have. Could make them myself but by the time I have bought the right tool to secure the ends it doesn't seem financially viable. Anyway, over too you lot, suggest away. P. ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Last Edit: Dec 30, 2021 13:19:01 GMT by Rich
Dec 30, 2021 13:15:04 GMT
Get the equivalent sized welding leads. They're much more flexible and are usually multi strand.
Dec 30, 2021 14:38:56 GMT
You can get the right tool for 20 quid. I’ve got one of the super cheap eBay special hydraulic jobs and it works fine. Add it to your watch list and within a few days they’ll send you an ‘offer’.
I then bought a few metres of decent cable and some ends, it came in way less than premade and I have the option of whatever length is right, not the closest length they want to sell you.
Paul Y
Dec 30, 2021 16:45:12 GMT
Thanks Dez, I will go and have another look now. Edit - For some reason I thought that these were £100, not £27... Watching a couple, will let you know, thanks again for the heads up. P. ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Last Edit: Dec 30, 2021 16:49:42 GMT by Paul Y
Paul Y
Dec 30, 2021 16:57:40 GMT
Ok Next question... Where are you buying your cable from? Prices seem to vary dramatically! P. ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Dec 30, 2021 18:18:03 GMT
Last lot I got was from ‘cablecuts’ via eBay. 5m of 50mm squ for £36. Decent quality, no issues with it.
By the time is bought two sizes of ends, the cable and the tool, and some red heatshrink to tag the ends of the positives, I’d spent about £80, but I did 3 cars with it and still have enough left to do at least one more of not a bit more. Way cheaper than buying em premade.
Dec 30, 2021 19:04:04 GMT
Can i add that the 70 mm sq super flexible welding cable i used was a bit over kill, lovely and flexible though
Dec 30, 2021 22:14:38 GMT
TBH, given that some modern stuff from about 2004 onwards can either
-damage your car -be damaged by jump starting them if not done correctly
I'd just get a jump pack. It's easier, quicker, and more of a lifesaver when you are in the middle of nowhere.
However, if leads are required, I'd do what Dez said.
Dec 30, 2021 23:37:29 GMT
Can i add that the 70 mm sq super flexible welding cable i used was a bit over kill, lovely and flexible though Nothing wrong with overkill. Beats melting cables.
Paul Y
Dec 30, 2021 23:41:33 GMT
TBH, given that some modern stuff from about 2004 onwards can either -damage your car -be damaged by jump starting them if not done correctly I'd just get a jump pack. It's easier, quicker, and more of a lifesaver when you are in the middle of nowhere. However, if leads are required, I'd do what Dez said. Chaz, Thanks for the comment but I have no idea what you re talking about! Are you finishing off the last of the Christmas Sherry?? LOL!!!!!!! P. ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Making new cables is best, but if your working to a budget e39 and e46 BMW's have some very useful cables in them.
