Sept 4, 2011 21:48:19 GMT
Well we took the car out to my dads and I popped it into the garage. I couldn't resist the spanners lol Basically I have 2 major jobs. Loom and fuel system. And a few minor jobs. Weld on lambda bung, make an idle control system, mount ecu, make throttle cable hanger, connect up servo and breather pipes Should do most of it in an evening I would have thought.
Sept 4, 2011 21:57:22 GMT
It looks more tame/stock now, hope it will run better with this setup.
Click picture for more
Sept 5, 2011 10:34:55 GMT
Yeah does look tame lol. I kinda prefer it, I think the engine bay will look empty and tidier Iam sure it'll run better and Iam confident that it will be almost same power ad carbs
valman
Sept 5, 2011 12:38:22 GMT
awesome thread, read from start to finish just now. given me lots of ideas for my k11 engine wise am i correct in thinking that if i too find a rover zs manifold, and chop it up a bit it will fit, provided i leave a screw hole for the lambda sensor, it would still run fine without a CAT? as I'm going to leave injection on for peace of mind and consumption figures, provided this would still work. got a bike can to go on mine that will fit perfectly too so might aswell make a whole new exhaust system for it while I'm at it and make a manifold fit cheers
Sept 5, 2011 13:07:01 GMT
Yea mate will work perfect with lambda and no cat.
The inner runners can be tweaked in with a vice but I recommend cutting the outer runners and rewelding at different angle. The most time consuming part wad the flange
Cheers dude
Sept 5, 2011 21:34:06 GMT
also i think all kseries engines come with 4branch. so when at scrapyard look for any rovers or mg i payed £20 off of ebay for mine but my local scrappy will do them for £15
Sept 5, 2011 21:59:33 GMT
Sept 6, 2011 12:56:41 GMT
Oh and forgot that I also fitted a Cg10 crank pulley as they are much lighter
Sept 6, 2011 20:41:37 GMT
valman
Sept 7, 2011 12:38:34 GMT
cheers for the advice swift! will have a look at the local scrappy and see what they've got, the volvo 340 i've got has a 4 branch too which i could cut up but i think it might be a bit too wide and would be too much effort to modify to fit. is the difference in the crank pulleys noticeable? cheers!
Sept 12, 2011 9:02:44 GMT
Yeah man ones thin steel the other is a huge lump of cast
Sept 20, 2011 8:52:37 GMT
Last Edit: Sept 20, 2011 8:56:54 GMT by swiftmini
Sept 20, 2011 9:11:03 GMT
Sept 20, 2011 9:13:28 GMT
Idle control works pulls but had to drill the hole in the throttle body out from 1mm to 6mm so that it starts from cold
Sept 20, 2011 10:30:07 GMT
This is my inspiration right now Iam tempted to get 14s or 15s too make it easier/better. Tempted to change colour And need a front splitter and some skirts and some rear spats
Sept 20, 2011 13:16:09 GMT
Anyone got any inspiration for me? Skirts ect?
Anyone know of an inspirational japhatch thread somewhere?
Sept 20, 2011 20:00:34 GMT
Nice job, as usual!
Wouldn't a Super S bodykit do the trick?
And with 175/55R15 tires on 7J alloys with low offset would look good.
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Sept 20, 2011 20:19:10 GMT
such a small world
Sept 21, 2011 10:39:24 GMT
Nice job, as usual! Wouldn't a Super S bodykit do the trick? And with 175/55R15 tires on 7J alloys with low offset would look good. Thanks mate (Y) Not sure about s kit, the skirts might work for me though I was thinking 14x9j banded corsa Sri steels with 185,60,14s with about 6* negative camber
Sept 21, 2011 10:42:25 GMT
such a small world Indeed it is, but when you want curse word from jp it could be smaller
