Sept 21, 2011 18:55:02 GMT
Nissan also offered different bodykits as an accesoire, most of them produced by Foha. Very eighties in style.
185/60R14 is quite large in diameter, They did scrub on my 35mm lowered Micra with 38offset (6J). But 6deg will alter things. I assume handling is not really an issue? 185/55 or 50 R14 are more expensive, but will fit the arches better.
Click picture for more
Sept 24, 2011 9:45:15 GMT
as title iam in desperate need of a k10 micra dip/flash relay that is on the inner wing of micra next to the coil.
I would also consider buying a complete car for the right money.
please pm me or post here if you have anything.
thanks kev
Home made performance clutch. Basically 2x luk cover plates, both diaphragm fitted into one cover Gave it a splash of silver hi-temp paint Then reassembled it yh And POW its ready for fitting and testiT] Kev spec performance clutch lo.
Rolling road on Thursday. Anyone fancy a guess at what power it'll make twas 98hp on webers
Is it pretty nippy then for an old micra? Nearly 100hp?? Looks pretty cool I must say.
Yeah man for a hatch back its quick. For a micra its ridiculous lol. I have beaten my mates 205gti off the lights, as well as mk2 golf gti and glanza turbo. Also destroyed a 207gti on a fast twisty road. High compression engine with cams and headwork is going in mid November
Can you still rev it as high as with the Webers? I'm inclinced to guess it around 85hp now, if you cannot achieve the revs. However you wouldn't be able to beat the mentioned cars. If you can rev it, it could be pretty much the same, perhaps you gain a little bit in in midrange. But I assume that the coolness of a Webers will add a couple of horsepower as well
Can you still rev it as high as with the Webers? I'm inclinced to guess it around 85hp now, if you cannot achieve the revs. However you wouldn't be able to beat the mentioned cars. If you can rev it, it could be pretty much the same, perhaps you gain a little bit in in midrange. But I assume that the coolness of a Webers will add a couple of horsepower as well It doesnt have a limiter The standard cams make full power at about 6000rpm. I personally think it has a lot more torque because it slips the clutch a lot more now! They are about 85hp as standard iirc
Anyone got any inspiration for me? Skirts ect? Anyone know of an inspirational japhatch thread somewhere? Awesome thread! Brings back memories of my K10, was getting ready to start engine mods (I'd swapped out the 4sp MA10 for a 5sp MA12 - but it needed lowering and more power) and a final sort out of the body work, but someone kindly crashed into my and wrote it off Not necessarily for inspiration, but for info... Keep up the good work, don't get rid!
It doesnt have a limiter The standard cams make full power at about 6000rpm. I personally think it has a lot more torque because it slips the clutch a lot more now! They are about 85hp as standard iirc Stock was 75hp in my schoolbook. The big plus of the Webers was that the intake traject was short and straight which helps to rev it and improve flow. The injection manifold isn't better in these aspects so I would expect less power. Anyway, it doesn't really matter. Because it is still an awesome Micra!
Anyone got any inspiration for me? Skirts ect? Anyone know of an inspirational japhatch thread somewhere? Awesome thread! Brings back memories of my K10, was getting ready to start engine mods (I'd swapped out the 4sp MA10 for a 5sp MA12 - but it needed lowering and more power) and a final sort out of the body work, but someone kindly crashed into my and wrote it off Not necessarily for inspiration, but for info... Keep up the good work, don't get rid! Hi mate thanks for the encouraging words And thanks for the inspirational pics, that car looked really good What front splitter and side skirts are they? Almost exactly what I want Iam hooked on my micra
Nice project - and the engine sounds like it will be a bit of a screamer.
Cheeky question - I don't suppose you have a spare CG10 flywheel kicking around? If so, could you measure the overall diameter of it? I'm pondering swapping possibilites and was wondering whether it would fit in my bellhousing. If not, a guesstimate would be better than nothing - a measurement of the CG13 wouldn't hurt if that's possible. Thank you in advance. ;D
Last Edit: Nov 2, 2011 16:25:11 GMT by jrevillug
Yeah man Wikipedia says 79 for cg13 and 85 for cga3 I was reading the wrong bit lol The carb setup had a really crappy inlet so I reckon I could have got lots more power from a nice inlet! The cga3 inlet that I have now is far from ideal Power figure by midday tomorrow Thanks for the compliments
Nice project - and the engine sounds like it will be a bit of a screamer. Cheeky question - I don't suppose you have a spare CG10 flywheel kicking around? If so, could you measure the overall diameter of it? I'm pondering swapping possibilites and was wondering whether it would fit in my bellhousing. If not, a guesstimate would be better than nothing - a measurement of the CG13 wouldn't hurt if that's possible. Thank you in advance. ;D Thanks mate (Y) I have a cg13 flywheel on the new engine Iam building, gotta take it off asap, so ill measure it and let you know. Next week I hope to swap engines so ill be able to measure the cg10 flywheel then, if that's any good for you? Cheers
I have a cg13 flywheel on the new engine Iam building, gotta take it off asap, so ill measure it and let you know. That would be great, thanks. Next week I hope to swap engines so ill be able to measure the cg10 flywheel then, if that's any good for you? No rush from my end - but it would be good to know. I hope the build and swap go well.
I have a cg13 flywheel on the new engine Iam building, gotta take it off asap, so ill measure it and let you know. That would be great, thanks. Next week I hope to swap engines so ill be able to measure the cg10 flywheel then, if that's any good for you? No rush from my end - but it would be good to know. I hope the build and swap go well. No worries and thanks
valman
awesome progress, look forward to seeing the power figure! i got an mg zr manifold for mine now thanks to this thread, so time to chop it about soon and fit it , mot first though,,, eek.
Lex
日本車 <3
Awesome
Resto-UKal
Thanks for the comments chaps 1st run 97.9hp 2nd run 98.1hp Lol
