Jul 16, 2012 22:53:39 GMT
Bad luck with the Bonnet, it could have been worse, it could have broken the windscreen as well Great to see progress here, loving the work so far I had the exact same problem with my bonnet when I took mine for a 'quick test', quite scary a 40+ mph as the bonnet is twice the size of the windscreen, mine stopped short of the windscreen as well but sheared off both hinges and bent the corners. I'm just going to make a fibreglass copy of my mates 'flat' bonnet though. Good luck gettin it sorted All the glass is of the car yet... It only bent abit where the hinges are bolted but nothing big... I've only noticed that when I was going to close it... The outer skin is almost undettectable... I'll see what I can do tomorow... I think I might have to change my water pump... It's leaking abit now... Maybe when I install all for the last time I remove all the rust in the water and change the water pump...
jonah
Jul 16, 2012 23:32:26 GMT
Keep it up, looking forward to see this finished.
Jul 24, 2012 19:40:10 GMT
Jul 26, 2012 21:12:15 GMT
Just got me some cheap spare parts... A New Old Stock diff for just £11... A good used «cam gear» for 1€... Always good to have some spare parts... just in case...
Aug 12, 2012 21:31:52 GMT
Just thought about my daily for some days because the oil consumption and since it doesn't smoke and the back end is covered in a fine spray of black oil it might not be the rings but the valve stems on the exaust side... Got to order some valve stems and the tools to replace them...
No update on this one... Just got me 2 badges for the grill, a AA one and a RAC one... I've opened the head and the fog lights to be cleaned and painted.. I don't know where I putted the seat belts, got to find them...
Aug 12, 2012 21:33:40 GMT
Is there 2 sizes of headlights for the volvo 164?!?!?!
Anyone knows?!?!
Aug 15, 2012 11:57:15 GMT
No one?!?!?!
Aug 27, 2012 22:16:19 GMT
No one?!?!?!
Aug 31, 2012 20:38:21 GMT
I think I've repaired my daily soo... progress soon...
Sept 1, 2012 15:43:32 GMT
Have a free comment, this is an awesome thread, just read the whole thing. keep up the good work
Sept 2, 2012 17:42:26 GMT
Have a free comment, this is an awesome thread, just read the whole thing. keep up the good work Thanks for the comment and the support...
Sept 8, 2012 12:38:29 GMT
Got me a new ATE master cilinder, some ball joints and some other bits...
Sept 18, 2012 21:24:55 GMT
Photos time... The new ATE master cilinder... The ball joints... New front wheel bearings... 5 Volvo 244 door handles New Volvo windscreen clips... More tommorow since the car work as stalled....
Sept 18, 2012 21:44:03 GMT
Sept 19, 2012 20:16:06 GMT
More photos of more parts... New front upper bushings... New front down bushings... New engine mounts... New Volvo panhard rod bushings... New Volvo water pump... 4 New rotor arms... New dizzy cap ... New front and rear brake pads... The old steering rubber cuppling...
Sept 21, 2012 4:53:06 GMT
Safe to say that lot should keep you busy for a day or two. Keep up the good work.
Sept 21, 2012 8:13:36 GMT
Excellent project, and a nice parts stash.
One thing though - intermotor points are awful. Please see if you can find some Bosch ones instead - they look to be a standard Bosch part - they'll last much longer and give a much better spark.
Sept 21, 2012 12:53:33 GMT
Safe to say that lot should keep you busy for a day or two. Keep up the good work. This is just some spare parts incase I might need since here the parts are a lot expensiver than in other countries... I know the intermotor points are curse word but I've got them cheap enough from Uk... Thanks for the comments...
Sept 21, 2012 21:04:24 GMT
More pics... New release bearing.. New Clutch plate Wait ... This is not the one... Here it is... New rear shocks... Repairing the fog lights... How they are... One just cleaned and painted... How they look in the back... The paint used... And the glass waiting for some TLC... Please comment...
Sept 23, 2012 20:13:01 GMT
Since no one knows I'll put some photos of the real diferences in the headlights... This is my volvo 164 headlight... This is one that I bought from the UK, among other parts... Exploded view of the one that came with the car... And the other one... Now side by side...
