Apr 18, 2013 20:19:43 GMT
another weekend on the motor so started totacke the drivers door,had to weld a section into the bottom but not as bad as the other side
So thats it getting along nicely and hoping to get the door finished over the summer then the body is done ;D
Last Edit: Oct 14, 2015 15:01:44 GMT by Deleted
Apr 20, 2013 20:17:11 GMT
smashing day to get out on the car so pushed her out to fit the drivers side sill
hope you all enjoyed drive it saw loads of classics today,Herald,Healey, frog eye, lotus smashing ;D
Last Edit: Oct 14, 2015 14:46:44 GMT by Deleted
Apr 28, 2013 18:51:54 GMT
more work on the drivers door enjoy
Last Edit: Oct 14, 2015 14:47:15 GMT by Deleted
Apr 28, 2013 22:10:56 GMT
LOL at the boss
top work
2001 HONDA CT110 (NOT RCV)
May 13, 2013 20:46:07 GMT
well fleebay purchase and i've got myself a set of alloy caterham hubs with ford stud pattern and uprated sealed bearings ;D and saved 200 quid into the bargain so well chuffed.
well that it for now cheers Rob
Last Edit: Oct 14, 2015 14:47:36 GMT by Deleted
May 23, 2013 18:56:06 GMT
what a build mate looking good !
more work do and the drivers side door is now all done and fits much better than the passengers side, the hood has been adjusted so i'm happy. Now time to remove the body and do the final bits of welding to the body and chassis, so off it comes
Also got the two alloy shod with some tyres.
Last Edit: Oct 14, 2015 15:01:56 GMT by Deleted
evening all, although it's been quite on the blog front progress has contiuned and the rear buck has now all been cleaned primed and stone chip painted need a caouple more cans but it will soon be ready for waxing
Last Edit: Oct 14, 2015 15:02:09 GMT by Deleted
[URL=http:// Cleaned up the diff and l found alloy casting under all the dust and grime, going to replace the seals and change the oil. Aslo painted up the diff carrier
Last Edit: Oct 14, 2015 15:02:27 GMT by Deleted
Aug 26, 2013 16:37:12 GMT
More work on the motor....
Last Edit: Oct 14, 2015 14:47:19 GMT by Deleted
Sept 1, 2013 11:00:11 GMT
bought myself a lathe, single phase load of bits and pieces thanks for looking
Last Edit: Oct 14, 2015 15:02:18 GMT by Deleted
Jan 21, 2014 15:46:58 GMT
Ok been a while since last post so here goes, the chassis has now been painted and all the rear suspension is on, the diff the exhaust manifold is finished just need fitting once l have sorted out the starter motor space that is in the lathe ready to have larges hole cut.
also finished the steering wheel and that is ready to fit to the column now l've got the steering lock to work and the indicator self cancelling.
thanks for looking
Last Edit: Oct 14, 2015 14:48:01 GMT by Deleted
carltonx
yardie in brum
Jan 21, 2014 17:39:24 GMT
looking very good
Potentially offensive comment deleted. You are welcome to remove this text, but not replace it with more bigotry. If the need to express that opinion is particularly important, please let me know and I'll delete your account for you. Maximum signature image height: 80 pixels.
Jan 21, 2014 18:15:13 GMT
Amazing build, can't believe i missed it up until now. Love the use of escort bits where needed [those old herald door locks were rubbish anyway, i seem to remember they'd fly open if you pushed it too hard round a corner...] how many horses will the zetec yield?
Jan 21, 2014 19:26:01 GMT
this is just incredible!
JP
eurogranada
Nice going!
Thanks guys Yes, when l borrowed it from my mum when i last rebuilt it for her(nearly 20 years ago) the door flug open on my girlfirend(now my wife), who was quite shocked as there were no seat belts in it at that time!! As for power zetec 1.6 is rated at 90bhp so with exhaust de-cat and air filter probably around 95 then with the auto box robbing some power l'm expecting a little faster than 13/60 but with a bit more torque as zetec has nearly 40 more than the 13/60. But later after l'm happy with the brake and suspension setup because l'm sure l'm going to have to change spring rating because the rear seams to hard and l've fitted vitesse front spring because although the engine is lighter than cast iron 6 the gearbox is heavier but that is also further back so we'll see. Then when l'm happy a zetec with supercharger/turbo going through 4 speed ford C4 gear box will go in and then power hike to around 160-180bhp!!
gavs1
what a build!!!!!! , and its good to see another triford in essex. bookmarked with pleasure
Jan 22, 2014 18:37:33 GMT
you've achieved what Harry Webster should have done 55 years ago - a decent rear end setup!
guess you can't really tell with the spring stiffness/heights until out on the road.
Great work, have enjoyed this thread
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 22, 2014 19:40:00 GMT
I wondered how things were going with this. Sterling progress sir!
