Thanks speede take it yours is either being `modified´ or awaiting better weather Yer bmwv8capri, wanted to engineer out the herald weak points, so the trunions have gone too remember reading about the herald prototypes being driven across African and almost everything broke!! just seamed to prove you shouldn't drive a herald across a desert!!! I do like your capri had a mk1 when l was younger, took it off the road to restore but never finished it ended up selling the solid shell to a block rebuilding a rotten RS3.1. gavs1 just read your thread yesterday completely missed it, going to be a rocket when you're finished. Been at mine for over 5 years now so fitting stuff on and not taking it off is a real mojo boost, wonse the starter is on l can fit the bulk head inplace and turn the engine over with the key
Last Edit: Jan 23, 2014 7:49:57 GMT by Deleted
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 23, 2014 10:09:08 GMT
Thanks speede take it yours is either being `modified´ or awaiting better weather Neither. It just sits outside the house and then every now and again I take it out for a damn good thrashing! lol I'm still trying to get my head around building the Megasquirt. The physical construction is no problem, but uploading the software etc is taxing me. Apparently I'm just not that proficient with computers!
Mar 19, 2014 12:22:55 GMT
Wifes daily has been causing go slow on the herald, basicaly we had realy nice estima and some stupid woman rammed straight into the Diesel oil and water leak 2 out of three fixed so far and just got MOT on it.
Also got the speedo done which was a right head scratcher l can tell you had to had 90 degree angle drive as no room and found no one made one also had to have output for speed sensor for the ECU even though the escort still had cable drive speedo. ] ebay came up trumphs with and angle drive off a volvo though must have metric thread and it did was only 3 quid because it was seized but easily got it freed up. Then took it apart and welded the other end to the auto speedo cable end and hey presto angle drive for less than a fiver result, also moded the drive cable so it was escort one end and herald the other!
chassis almost ready to put the bulkhead to go on, just need to fit the starter motor and kick down cable.
Thx
Rob
Last Edit: Oct 14, 2015 15:03:16 GMT by Deleted
eurogranada
Mar 20, 2014 10:34:49 GMT
Nice!!
Apr 23, 2014 21:41:37 GMT
Small update, the front bulk head is back on and it doing to stay there...........hopefully!
Last Edit: Oct 14, 2015 14:48:25 GMT by Deleted
Apr 23, 2014 22:55:35 GMT
Starting to look mighty fine Rob....Don't let the Audi distract you
69 Herald 13/60 with Turbo 1600 MX5 engine, Lexus 5 link rear end, 17in wheels,300mm ventilated disc's and subaru 4 pot calipers
scimjim
Club RR Member Number: 8
1969 Triumph Heraldscimjim
@scimjim
Club Retro Rides Member 8
Apr 23, 2014 23:16:50 GMT
just read the whole thread - great build I'm doing an auto mx5 into a Scimitar Sabre (Ford diff as standard). We discounted a 3 speed auto on the standard RWD CVH as it would be too revvy at motorway speeds (although it would have fitted with next to no mods!) - what ratio do you have, 3.92?
Apr 24, 2014 20:45:36 GMT
just read the whole thread - great build I'm doing an auto mx5 into a Scimitar Sabre (Ford diff as standard). We discounted a 3 speed auto on the standard RWD CVH as it would be too revvy at motorway speeds (although it would have fitted with next to no mods!) - what ratio do you have, 3.92? thanks Scimjim, it will probably be a bit revvy but am thinking when l fit the super charger later l'll use the C4 with the overdrive, but at least with the sierra diff l can have a chose of ratio's . anyway big fobar, went to fit the body on and it fouls the prop near the hand brake lever so had to cut the complete area out, sorry no pictures because l was a tad annoyed after painting it all Also then ran out of mig wire and gas!
Apr 24, 2014 20:46:13 GMT
ferny
Club RR Member Number: 13
1969 Triumph Heraldferny
@ferny
Club Retro Rides Member 13
Snap! Kinda. My handbrake fits but has to stay up. Trying to decide whether to rotate it slightly, move it to one side or a combination of both. What you gonna do yourself?
Em
Fuel Injected? Carb Infested!
Apr 25, 2014 17:53:06 GMT
Coming on nicely Rob! anyway big fobar, went to fit the body on and it fouls the prop near the hand brake lever so had to cut the complete area out, sorry no pictures because l was a tad annoyed after painting it all That's a bit of a b*gger but the sort of thing you have to expect now and again when doing such radical surgery!You'll sort it!
Apr 25, 2014 19:18:32 GMT
Snap! Kinda. My handbrake fits but has to stay up. Trying to decide whether to rotate it slightly, move it to one side or a combination of both. What you gonna do yourself? Thanks Fern, been following your mx5 herald was using the escort handbrake anyway so l'll have to sort a new cable routing and lever mounting.
Apr 25, 2014 20:02:56 GMT
Superb work , is the green on the bulkhead going to be the body colour ?
Apr 26, 2014 12:18:02 GMT
Superb work , is the green on the bulkhead going to be the body colour ? Oh yes it's RangeRover Evoque Colima Green, doing inside with rattle cans so l can fit everything and then get someone to paint the outside.
So this is the big gapping hole l had to cut out to clear the prop.... this is about where the hand brake lever will sit just need to run up some mounting plates and weld them inplace thi si the bloody third time l have fitted the handbrake lever!!! thi is the third time l have fitted the hand brake lever ..... so all the stuff l have fitted to the bulkhead will have to stay as the loom has been fitted now. It will just be a bit heavy....dooh Thanks for looking, will report the next"what the curse word" saga!!!!
Last Edit: Oct 14, 2015 15:03:36 GMT by Deleted
Nov 11, 2014 15:53:02 GMT
Anyway fixed the gear linkage so have continued slowly, the inside is painted and the boot is done also fitted the tank and the battery, moded the upper wishbone with some lada track rod ends so caster in adjustable.
Enjoy...
Last Edit: Oct 14, 2015 14:48:39 GMT by Deleted
Jan 19, 2015 11:12:59 GMT
Still busy putting front suspension and brakes on, one side all done now, fitted spherical joint to the lower to bin the trunions just fitted alloy wheel to check clearance Also big mojo boost when you turn the key the engine turns over, just need to add fuel now Thanks for looking.
Last Edit: Oct 14, 2015 15:04:00 GMT by Deleted
MrSpeedy
East Midlands
Jan 19, 2015 16:35:48 GMT
Nice to see some good progress on this. keep it going mate
Nice to see some good progress on this. keep it going mate Still progressing MrSpeedy, sorting more of the electrical gremlins even though l am using the escort wiring loom found the wiring to the brake lights was fubar and the brake switch was shot as well, sorted the starter inhibitor for the auto box by adding a relay, the problem l have found is the all the gauges in the Herald were historical for + earth and the escort used - earth, but the 13/60 Herald was - earth l hear you say and yes it was but the gauges still worked other way round so all they did was use the earth to switch it. So l have bought an escort dash and will graft the escort fuel and temp gauge into the herald dial cluster This leads me into the next job, the wooden dash was shot with extra hole cut and water damage, so a trip the B&Q and found an ideal replacement no not another bit of timber, a length of gutter facia board water proof and easy to cut with the added bonus of it being paintable This with the centre console will be body colour so it matches the door tops. Thanks for looking!!
Last Edit: Oct 14, 2015 15:04:20 GMT by Deleted
Well dash has been painted l these shots show it offered up and l can say I'm please with the result and it will look different than original but still a retro theme, think i'll put some early herald badge under the heater controls, the clock and retro look audi are going in the center stack when that is painted, my brother has finished the front seats so need to build the rear seat, going to use a Ka rear seat because it looks about the same size but a trawl over the local scapy should come up trumps If you are wondering what the little rocker switches are they are electric window switches
Last Edit: Oct 14, 2015 15:04:30 GMT by Deleted
