+1 great attention to detail! there can't be too many of these left in good nic
had a 126 as an everyday driver years ago, it was great fun, even with the gearstick trying to occupy the space where my knee needed to be.. (though it really needed a bit more power & better brakes) on severe cornering the rear-end would suddenly swop-ends when you least expected it - just like a miniature Porsche!
May 14, 2016 21:11:43 GMT
mt796 - As requested here is an update for you. bmwv8capri - Thanks pal, I always appreciate recognition to my attention to detail. I hear you about the gearstick, I'm 6'4" so I'm guessing you're also tall? Not had a chance to drive this on the road yet but I'll certainly heed your warning! So time for an update on the little BIS. The dust sheets were removed and he was wheeled out from the corner to do some work on him. First up, I fitted my newly trimmed door cards to the passenger door. You may remember I had the interior retrimmed. I really liked the original material but it was clearly cheap and not made to last. I hope my choice will stand the test of time. Door card fitted. Also here is a little comparison next to the seat to show you the match. Next up it was time to get the welder out. You may remember I had the matching rot in both sides of the outer sill. It's obviously a common place for these to go as both sides had already been badly plated. So I made a couple of plates up from some sheet to fill both sides. I then shaped it in to position to make sure it fitted well with a joggled top edge. My welds aren't brilliant as I'm a complete amateur, so I've taken a pic after it was welded and ground flat! I then got the filler out! I then flatted down the filler, it was always going to go back to textured stone chip so I didn't go too detailed on the sanding. Just got it smooth and levelled out. Next up I applied the white stone chip to the panels, to achieve the textured rough effect like the rest of the sill I dabbed it gently with a sponge to achieve the similar desired result. I was quite happy with it in the end. It does need another dust over with the stone chip once it's dried just to get rid of the dark parts. It takes a few hours to dry so he was pushed back in to the corner to dry. As usual though. Thanks for looking and all comments welcomed and appreciated.
Last Edit: May 14, 2016 22:51:37 GMT by blacksaff
Twitter @w0rd5w0rth
1957 Ford Prefect 1965 Austin 1100 4 door 1968 Fiat 500L 1969 Ford Escort Super 1971 Vauxhall Viscount 1974 MGB GT 1978 Vauxhall Cavalier GL 1981 Ford Capri GL 1982 Ford Cortina Crusader 1985 Vauxhall Cavalier L 1987 Austin Maestro City 500 1987 Ford Fiesta 1.1L 1988 Volvo 240GL 1989 Ford Sierra Cosworth 1991 Fiat 126 BIS 1993 BMW 740i 1997 BMW M3 Evo 1998 Ford Transit Beavertail 2002 MINI Cooper S
Just read this from start to finish - what a fantastic job you've done on it!
1988 Ford Fiesta Popular Plus Daily 1978 Triumph Spitfire Project 2002 Nissan Almera Tino Budget Build!
May 27, 2016 19:05:17 GMT
br00klyn99 - Thank you buddy, comments like that well appreciated. Time for an update again on the BIS. I finished off the repairs on both the sills. I'm quite happy with the end result, to try and achieve the OEM underseal look I let the stonechip dry till tacky, then dabbed it with a sponge. Now cast your memory back to the early part of this thread, to a job I've been putting off for some reason. The chips in the top of the door. To begin I rubbed the area down. After a good coating of filler primer, I then applied several thin coats of Fiat Blanco Corfu to build up the colour. Once cured and happy with the end result I gave a few coats of lacquer and removed the masking tape. I also fitted the drivers side door card and furniture. Really happy with how it turned out in the end, not much left to do on the little BIS. Thanks for looking.
Twitter @w0rd5w0rth
