Aug 12, 2008 16:04:32 GMT
might be needing a van and these look handy and a little different to the normal small white vans I see all the time
anyone ever had one? just wondering what they are like to service and drive
ta matt
*HTW Edit - Title was all caps, now corrected.
Last Edit: Aug 12, 2008 16:10:01 GMT by HoTWire
Aug 12, 2008 16:13:10 GMT
We used to run a coupe of V Reg ones when I worked for a motor factors, they were cheap and cheerful. We used the 1.8 diesel models, which were quite nippy but the brakes were curse word, upgraded to EBC green stuff pads which helped. And don't put to much weight in the back as they become unstable!. (I nearly killed myself once delivering a 205Lt drum of oil in the back of one!) But apart from that, they are dirt cheap to run and buy, one van we had done 130k in 5 years with no real problems apart from trim breaking or falling off and the rear lights blowing every other day, typical French build quality really!. Here, have a photo of my old work van from from about 5 years ago And here's one taking a corner at 20 mph with a bag of plaster in the back...
Last Edit: Aug 12, 2008 17:42:39 GMT by trigger
Aug 12, 2008 16:23:04 GMT
Try having a look at a Fiat Fiorino 1.7TD, as you get 40 mpg, a nice car like cabin, space in the back for a full size bath (if thats the sort of thing your interested in), and they can easily take the weight (2 scrap cast irons baths, and the rest of the suites at a time). Plus they don't look that modern (look like a mid 80's Fiat Uno with a box on the back) edit - what ours looks like...
Aug 12, 2008 16:25:52 GMT
GF's dad has one, had it 1.5 years since we got our van off him. He's not broke it yet and he broke a Sierra 1.8 pinto eventually with neglect. still plenty these about. Basically a Visa yeah?
Aug 12, 2008 17:36:31 GMT
Yup. A Visa van that just refused to go out of production! Until they did a few years ago...
Hardy little things, although switchgear can be a bit breaky. As mentioned above, with lots of weight in the back, they handle like a wheelbarrow full of paving slabs. I drove one with er, quite a few people in the back (thankfully not very far...) and it was bloomin' hard work!
1986 Citroen 2CV Dolly Other things. Check out my Blog for the latest! www.hubnut.org
Aug 12, 2008 17:46:08 GMT
Last Edit: Aug 12, 2008 17:48:15 GMT by TYP 19
Aug 12, 2008 17:54:42 GMT
My dads had loads. they're cheap, basic motors, the engine is the best part of them. The rear suspension can go wonky, the cab is crampt, older ones can rot pretty badly but they're reliable, take loads of stick and have some character. I like them!
Aug 12, 2008 18:11:37 GMT
Aren't the 1.9 'DW8' engines used in late ones a bit shonky? I would like to try one out, I bet they're quite amusing.
Aug 12, 2008 18:22:31 GMT
I have had a couple now and run one day-to-day as a hackabout / parts fetcher. Its the 1.8 diesel engine, which is robust, but not that refined. No matter what style driving I do, its simply refuses to give any worse than 51mpg, and often a fair bit better than that. Rear load space is good (better than a vauxhall combi I'm led to believe?) and it will take 600 kgs payload, which is impressive. The cabin is basic but functional. Common faults are the twin-speed heater fan failing on one speed, door check-straps pulling out the doors, allowing doors to flap open too far and hit the wing, window winders can fail too, along with general citroen nasty hard plastic dashboards that split, crack and rattle. Rust on the sills, front edge of the bonnet and bottoms of the doors. Also rust-scabs on the bit above the cab roof as with most of this style of van from untreated stone-chips. Check the rear wheels arent wonky with excessive camber - a sign of worn beam bushes. A common problem and best bet is to bin the whole rear beam and fit a good one as repairs are a bit tricky without the right tools. Handling can be interesting, but I quite like it. Cheap tyres don't do them any favours in the grip department at all.
EDIT - most are Lucas diesel pumps I think. Mine certainly is, so veg oil isnt advisable.
Last Edit: Aug 12, 2008 18:27:40 GMT by dave21478
1986 Panda 4x4. 1990 Metro Sport. 1999 Ford Escort estate.
Aug 12, 2008 18:26:04 GMT
Aug 12, 2008 18:52:05 GMT
begging for some treatment IMO
bstardchild
Club RR Member Number: 71
Aug 12, 2008 19:06:01 GMT
My Brother in Law has one - borrow it whenever I need to move some tat - brilliant little tool - swallows loads of stuff - I got four senator doors in the back with space to spare drove them down from Norfolk to Reading and picked up a huge bit of furniture and brought that back - averaged 60mph and close to 50mpg from a smelly oil burner
Aug 12, 2008 21:09:06 GMT
not thought of a florini ill look into those too any idea if these run on veg oil? no a problem as I'm not doing mega miles just curious also ive seen 2 with side windows now,do any of these have rear seats or a option when new to have them?
Aug 12, 2008 21:18:02 GMT
its the xud engine fitted to many of the french cars it will run on veg aslong as it has the bosch fuel pump but be warned the price of veg oil is higher than derv at the moment unless you can filter it theres not much point
Aug 12, 2008 21:48:30 GMT
side windows are an option on them, but as far as I know, the 4-seaters were never sold in UK. They were sold here in France as a normal 4-seater van, and also a longer wheelbase version, again with a rear bench seat. Other factory oddities are a 4x4 version and a 6-wheeler, again never sold in uk, sadly.
Side windows are a definate advantage though, visibility is poor otherwise when checking blindspots or pulling out of junctions that arent a straight T shape. The steel panels are just bonded in, so yu can hoik them out and fit the windows if you find a set with the rubber seals.
Last Edit: Aug 12, 2008 21:50:14 GMT by dave21478
Aug 12, 2008 21:53:29 GMT
don't buy a petrol one. They have the 1.4 tu engine and are depresingly slow. The earlier petrols had the laid back engine and were just as slow and rattle to boot. The diesel is a nice van in a 'not quite like any other van you'll ever drive' kind of way.
skinnylew
Club RR Member Number: 11
Aug 12, 2008 22:21:01 GMT
Buy a petrol one and slap a Saxo VTS engine and have 120bhp+ on tap
Aug 12, 2008 23:11:02 GMT
My dad had one for a while... Common faults are... door check-straps pulling out the doors, allowing doors to flap open too far and hit the wing, It had that And that. And that's what scrapped it He picked me up from uni in it once and it did High Wycombe to Bath and back, fully loaded, on quarter of a tank. Pretty good really.
1989 Peugeot 205. You know, the one that was parked in a ditch on the campsite at RRG'17... the glass is always full. but the ratio of air to water may vary.
Aug 12, 2008 23:51:46 GMT
here's mine: don't get one. lol OK good points - it goes on forever, reliable little engine bad points - handles like utter utter cr@p, light bulbs pop on a regular basis, heater gives up, awful to work on (about 3 hours to change the sodding glow plugs!) cheap and nasty french design, made out of tinfoil, rusts as soon as you look at it. Kirsty
I have determined that my sole purpose in life is to serve as a bad example...The Old Girl's page: www.ukshires.net/saabstory.htm CURRENT vehicles - '84 Saab 900 turbo classic, '87 GMC vandura V8, '94 Nissan 200SX S13, 2005 Vauxhall Vectra estate.
you like it then lol
