Oct 10, 2008 23:51:23 GMT
Oct 11, 2008 12:17:09 GMT
from what i gather on google it's a diesel turbo used on several Mazda's
1985 MK2 Golf
Oct 11, 2008 16:48:01 GMT
have looked into it and it is a variable geometry turbo. i've been told this give problems on petrol engines.
Oct 17, 2008 21:42:56 GMT
Oct 17, 2008 22:36:31 GMT
Where did you get those weld in vents from? Like the amount of metal you have replaced. Seeing all that rust being cut out makes me happy!
Oct 17, 2008 23:18:56 GMT
they are off a late 1600 decklid i bought for a fiver, not exactly the right vert ones but look ok. yeah i had a think the other day and not much of the original car left, roof, tunnel...emmm....
chaz
Stunning car and different, I like it.
jammee
oh curse word!
Oct 23, 2008 18:54:32 GMT
love it pal excellent
slam it till the wheels fall off
jammee
oh curse word!
Oct 23, 2008 18:56:52 GMT
does that engine bolt upto a standard bug box?
Oct 23, 2008 21:02:25 GMT
Loving that! Did'nt realise you got that much HP in a WBX! and the front valance is really subtle! Loads better than drilling a million holes in your bonnet! Maybe I should go for a WBX motor in mine next time i rebuild it! Loads more HP for your money!
Nice one mate!
Its all about balance and co-ordination. How hard can it be?
Oct 24, 2008 19:51:51 GMT
does that engine bolt upto a standard bug box? yep, exact fit, the flywheel needs to be changed from a 235mm to a 200/210/215mm type4 one though, and input shaft is shorter so yo need to fit a needle bearing to the flywheel. Loving that! Did'nt realise you got that much HP in a WBX! and the front valance is really subtle! Loads better than drilling a million holes in your bonnet! Maybe I should go for a WBX motor in mine next time I rebuild it! Loads more HP for your money! Nice one mate! yeah it is a nice option, altho after trying the power next time i may go for a scooby lump as there are loads more parts about for it. saying that... i am hoping to get new MS EFI and turbo for it and that should be scary enough for now.
Oct 25, 2008 14:57:45 GMT
carmad
theres still 1" there
cracking build i really really like this one
theres still 1" there cracking build I really really like this one not if i get in the car! thanks geez
Anglia68
Powered By Boredom.
Oct 26, 2008 20:18:36 GMT
It just keeps getting better and better,love it.
Oct 30, 2008 23:12:41 GMT
Very nice Bug you have there dude. Keep up the good work. Wish could get my car that low. ;D
Very nice Bug you have there dude. Keep up the good work. Wish could get my car that low. ;D thanks dude, it's all a case of cutting
more things, after busy month doing panto i am back on it. been cleaning heads and engine dunno if i showed you but i have made ali door cards for simplicity also fitting a later/modified pedal assembly
thats well good. really good bug build loving it. oh and whats the "mesh" on the front from, seems nice and thick to tack on. cheers.
