Jan 10, 2012 22:12:25 GMT
A little bit more done on the front, I'm quite indecisive about how to shroud the radiator so just knocking things off the list so it simplifies options. I have put some side panels in to turn the wobbly profile of the inner wing in to a straight one so I can later make a nice square cover over it. Also I have trimmed the original front valance edge and extended it as to duct air better to the radiator. I have a bit of time off soon so I should be able to get more done. This is good.
Jan 11, 2012 20:07:54 GMT
Looking good i havent seen this done before. It looks like a DJ motor which has nice power range are you going to upgrade the box to a 5 speed aswell? You could get a trans strap to help tie the engine down a bit probably ought to stick some discs on the front too! have fun
Jan 11, 2012 22:16:47 GMT
Thanks, I'm hoping to swap the whole lot to a golf engine and box at some point. still need to see though. And brakes are on the cards as I've driven it with this engine before and it's a bit nuts.
Jan 20, 2012 21:02:28 GMT
Cracking on with the radiator tin, it takes ages to get the profiles work with the original shapes so allot of fitting and fettling. That however makes it look like I work at a snails pace. I am however getting there, got a fair bit done until my wire ran out so the remaining bits and the valance will have to be done monday.
Jan 25, 2012 21:54:00 GMT
So I got the Front valance sorted, It took a while but now looks nice, however I did curse word up the alignment a bit so it's not 100%. I closed off any holes that would let any air or water in to the bonnet, there are a couple of pinholes but they will be sorted when it's seam sealed. The tube for the bonnet catch cable is now in to bits to make it easy and be able to remove the valance. I also finished up the valance trim and added some captives to make it easier to remove.
Finally got the front ready for paint, gave it a quick once over with primer today, I'm glad I have no more filling and sanding to do for now.
Onne
Looking good!
luckygti
I need to try harder!
Amazing work, this thing should fly, the 2.1 in my DoKa made it pretty quick and that weighs, well, quite a lot
Thanks guys, yeah i'm looking forward to it now, plus it should mean 3 out of 4 cars on the road...
Feb 16, 2012 21:35:18 GMT
Feb 21, 2012 20:44:25 GMT
Had a bit of a clear up and I'm waiting on some bits so not much done at the moment but here's a couple of pics. Note the powerful front brakes.
Feb 21, 2012 22:55:17 GMT
DRUMS!? I really don't mean to sound offensive......but are you on crack!
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
sparkyt
selling stuff
Feb 21, 2012 23:08:16 GMT
You only kidding around ..... right ? .. your not running the drums ..
Feb 22, 2012 13:07:57 GMT
I will be making another whole front setup once it's got an MOT. At the moment it's just so I can get it legal, rolling and out of the barn. One will be taking it easy until actual brakes arrive.
Feb 23, 2012 21:12:41 GMT
Cracked on a bit with the rear as I'm waiting on some bits for the front today and I made up the brake fluid reservoir. I need some hose before I can plumb it in.
All the rear is empty and ready for a clean before I finish and paint it. And the new wires are getting laid out.
Mar 17, 2012 20:21:54 GMT
